Magnavox Provincial
Ron,
I have a WC 356-1 changer in my Magnavox Belvedere and this one is very different.
I believe this one may be a Collaro from late 1940s.
The tone arm looks a lot like the ones on a Collaro TC-99. Record stabilzer arm has a hole that fits over the spindle.
Has all functions in one control; off, 78, 45, 33 rpm and reject. The reject pushbutton ( operates solenoid) is located in the center of this knob. Has a large 4 pole motor.
Information for CR242 chassis is in Riders 22 Nostalgia Air record changer information may also be in this volume or volume 23. I don't have these volumes.
Tone arm will not lift high enough or move aside enough to get to the cartridge. I think it may snsp on at the pivot point but I want to know how to remove without damaging it.
Thanks for your help. Paul
Magnavox Provincial - by PFJC2 - 02-22-2011, 07:45 PM
Re: Magnavox Provincial - by Ron Ramirez - 02-22-2011, 09:59 PM
Re: Magnavox Provincial - by PFJC2 - 02-23-2011, 12:28 AM
Re: Magnavox Provincial - by Ron Ramirez - 02-23-2011, 10:14 AM
Re: Magnavox Provincial - by Doug Houston - 04-17-2011, 12:03 AM
Re: Magnavox Provincial - by PFJC2 - 04-17-2011, 09:15 PM
Re: Magnavox Provincial - by Ron Ramirez - 04-18-2011, 05:43 AM
Re: Magnavox Provincial - by Doug Houston - 04-18-2011, 05:32 PM
Re: Magnavox Provincial - by PFJC2 - 04-20-2011, 04:16 PM
There are currently 10138 online users. [Complete List]
» 1 Member(s) | 10137 Guest(s)
