38-7 bought today
It's at 800 now, isn't it? I believe it started on 540 in 1932. Regardless, I like the 38-7 with CKLW on the dial. Didn't the 38-4 also have these regional dials?
Mike
38-7 bought today - by FStephenMasek - 02-19-2011, 10:45 PM
RE: 38-7 bought today - by FStephenMasek - 11-08-2012, 08:09 PM
RE: 38-7 bought today - by Ron Ramirez - 11-08-2012, 09:21 PM
Re: 38-7 bought today - by exray - 02-20-2011, 09:29 AM
Re: 38-7 bought today - by Michael Dennis - 02-20-2011, 01:20 PM
Re: 38-7 bought today - by FStephenMasek - 02-21-2011, 11:26 AM
Re: 38-7 bought today - by Michael Dennis - 02-21-2011, 11:28 AM
Re: 38-7 bought today - by Ron Ramirez - 02-22-2011, 09:07 AM
Re: 38-7 bought today - by Arran - 02-22-2011, 11:35 PM
Re: 38-7 bought today - by Doug Houston - 02-23-2011, 12:11 AM
Re: 38-7 bought today - by Michael Dennis - 02-23-2011, 01:26 AM
Re: 38-7 bought today - by brianclara - 02-23-2011, 11:51 AM
Re: 38-7 bought today - by Chuck Schwark - 02-23-2011, 12:10 PM
Re: 38-7 bought today - by Chuck Schwark - 02-23-2011, 10:41 PM
Re: 38-7 bought today - by Steve Chambers - 02-23-2011, 10:57 PM
Re: 38-7 bought today - by FStephenMasek - 02-27-2011, 01:27 PM
Re: 38-7 bought today - by ekimetsok - 02-28-2011, 10:44 AM
Philco 91 Tuning Condenser
There are currently 4401 online users. [Complete List]
» 1 Member(s) | 4400 Guest(s)
