Home AM radio station
Regarding hum with my Talking House transmitter. Had to disable the safety ground connection on the wall wart. Used a 3-prong to 2 prong adapter from hardware store.
Richard
Home AM radio station - by jepstr67 - 10-21-2010, 09:20 PM
Re: Home AM radio station - by P40-165k - 10-21-2010, 09:46 PM
Re: Home AM radio station - by Ron Ramirez - 10-24-2010, 07:32 AM
Re: Home AM radio station - by jepstr67 - 10-24-2010, 03:18 PM
Re: Home AM radio station - by Glenn Roberts - 10-24-2010, 03:35 PM
Re: Home AM radio station - by w4rtc - 10-24-2010, 09:02 PM
Re: Home AM radio station - by jepstr67 - 10-24-2010, 09:09 PM
Re: Home AM radio station - by w4rtc - 10-24-2010, 10:58 PM
Re: Home AM radio station - by jepstr67 - 11-06-2010, 09:53 PM
Re: Home AM radio station - by FStephenMasek - 11-07-2010, 12:31 AM
Re: Home AM radio station - by jepstr67 - 11-07-2010, 11:07 AM
Re: Home AM radio station - by Raleigh - 11-30-2010, 07:12 PM
Re: Home AM radio station - by Ron Ramirez - 11-30-2010, 08:02 PM
Re: Home AM radio station - by jepstr67 - 02-20-2011, 02:40 PM
Re: Home AM radio station - by 7estatdef - 02-21-2011, 01:01 PM
Re: Home AM radio station - by andyjon100 - 02-21-2011, 02:12 PM
Re: Home AM radio station - by jepstr67 - 02-22-2011, 07:09 PM
Re: Home AM radio station - by Ron Ramirez - 02-22-2011, 09:50 PM
Re: Home AM radio station - by jepstr67 - 02-22-2011, 11:01 PM
Re: Home AM radio station - by rghines1 - 02-23-2011, 04:01 PM
Re: Home AM radio station - by jepstr67 - 03-01-2011, 07:29 PM
Re: Home AM radio station - by Steve D - 03-02-2011, 09:18 AM
Re: Home AM radio station - by Ron Ramirez - 03-03-2011, 08:59 AM
Re: Home AM radio station - by jepstr67 - 03-04-2011, 10:43 AM
Re: Home AM radio station - by Chicago Jimmy - 06-22-2011, 02:52 PM
Re: Home AM radio station - by Arran - 06-22-2011, 08:18 PM
Re: Home AM radio station - by etech - 06-22-2011, 10:30 PM
There are currently 8420 online users. [Complete List]
» 1 Member(s) | 8419 Guest(s)
