Philco 41-608 add AUX input thru Phono RCA Jack
thanks, in the schematic there is already 0.006uF cap before the grid (actually it was changed to 0.003uF in a later model). the RCA cable connects to that cap. Would you know what cable Philco used to connect phono to the chassic i cant find that type of cable anywhere.
RE: Philco 41-608 add AUX input thru Phono RCA Jack - by chalupa13 - 09-11-2020, 03:58 PM
