Varnishes for radio cabinets ... What types?
It's possible someone used another polish or protectant product on your radio later in it's life, and that is what is reacting when you try to remove the finish. I know there are some "restoration" products that are a no-no to use, if you want to refinish your radio or furniture in the future. Products with silicone in them are bad...
RE: Varnishes for radio cabinets ... What types? - by Brad Winder - 09-15-2020, 12:45 AM
