37-610 completed!
I was able to clean the knobs. I used a small blunt tool to lightly scrape out the dirt, then back to the tooth brush soap and water. Worked great! This was the first radio that sold at the swap meet!
Tony
37-610 completed! - by tbone - 09-07-2020, 12:59 PM
RE: 37-610 completed! - by morzh - 09-07-2020, 02:34 PM
RE: 37-610 completed! - by tbone - 09-07-2020, 06:39 PM
RE: 37-610 completed! - by morzh - 09-07-2020, 06:47 PM
RE: 37-610 completed! - by Paul Philco322 - 09-07-2020, 07:33 PM
RE: 37-610 completed! - by tbone - 09-07-2020, 08:14 PM
RE: 37-610 completed! - by morzh - 09-07-2020, 09:42 PM
RE: 37-610 completed! - by NostalgiaRadioTime - 09-07-2020, 10:02 PM
RE: 37-610 completed! - by tbone - 09-18-2020, 10:04 AM
RE: 37-610 completed! - by morzh - 09-18-2020, 02:11 PM
