Another aqusition a Model 20
I believe that the two chassis are very similar, the only exception might be the late model 21s that used 45s for output vice the 71s. I only know the model 21 from a friend that restored one, so my knowledge is not first hand. I know Dick also makes cabinet parts for the model 20 radios as well. Not sure if Steve Davis does these models or not, but it is worth checking.
You have two radios that would look swell next to each other after you finish them!
Another aqusition a Model 20 - by 7estatdef - 02-26-2011, 07:00 PM
Re: Another aqusition - by TA Forbes - 02-27-2011, 01:00 AM
Re: Another aqusition - by 7estatdef - 02-27-2011, 09:31 AM
Re: Another aqusition - by TA Forbes - 02-27-2011, 02:07 PM
Re: Another aqusition - by 7estatdef - 02-27-2011, 03:26 PM
Re: Another aqusition - by 7estatdef - 02-28-2011, 09:15 PM
Re: Another aqusition - by 7estatdef - 02-28-2011, 10:22 PM
Re: Another aqusition - by 7estatdef - 03-01-2011, 09:22 AM
Re: Another aqusition - by 7estatdef - 03-01-2011, 11:01 PM
Re: Another aqusition a Model 20 - by 7estatdef - 03-02-2011, 11:06 PM
Re: Another aqusition a Model 20 - by Ron Ramirez - 03-03-2011, 08:48 AM
Re: Another aqusition a Model 20 - by 7estatdef - 03-17-2011, 05:51 PM
Re: Another aqusition a Model 20 - by codefox1 - 03-18-2011, 10:36 AM
Re: Another aqusition a Model 20 - by 7estatdef - 03-18-2011, 05:44 PM
Re: Another aqusition a Model 20 - by 7estatdef - 03-18-2011, 07:04 PM
Eico 232 VTVM Schematic
There are currently 6493 online users. [Complete List]
» 2 Member(s) | 6491 Guest(s)
