Just Picked up a 42-350 AM/FM/SW Radio today!
Yeah I knew that it was the old FM band, but I was curious as to if the radio could be modified to make it play the current FM band, if not it still has AM and SW which do work still.
There are currently 5143 online users. [Complete List]
» 1 Member(s) | 5142 Guest(s)
