38-7 bought today
The dark spot on the top of my radio appears to be a spill, perhaps of wax. I scraped it with my fingernail at the auction, then briefly scraped most of it off after bringing it home. Today is cool, but sunny, so I may strip the cabinet.
Chuck's dial listing is quite interesting. I did not check all of the stations, but the Los Anegles dial is still correct for KFI (640) and KNX (1070).
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
38-7 bought today - by FStephenMasek - 02-19-2011, 10:45 PM
RE: 38-7 bought today - by FStephenMasek - 11-08-2012, 08:09 PM
RE: 38-7 bought today - by Ron Ramirez - 11-08-2012, 09:21 PM
Re: 38-7 bought today - by exray - 02-20-2011, 09:29 AM
Re: 38-7 bought today - by Michael Dennis - 02-20-2011, 01:20 PM
Re: 38-7 bought today - by FStephenMasek - 02-21-2011, 11:26 AM
Re: 38-7 bought today - by Michael Dennis - 02-21-2011, 11:28 AM
Re: 38-7 bought today - by Ron Ramirez - 02-22-2011, 09:07 AM
Re: 38-7 bought today - by Arran - 02-22-2011, 11:35 PM
Re: 38-7 bought today - by Doug Houston - 02-23-2011, 12:11 AM
Re: 38-7 bought today - by Michael Dennis - 02-23-2011, 01:26 AM
Re: 38-7 bought today - by brianclara - 02-23-2011, 11:51 AM
Re: 38-7 bought today - by Chuck Schwark - 02-23-2011, 12:10 PM
Re: 38-7 bought today - by Chuck Schwark - 02-23-2011, 10:41 PM
Re: 38-7 bought today - by Steve Chambers - 02-23-2011, 10:57 PM
Re: 38-7 bought today - by FStephenMasek - 02-27-2011, 01:27 PM
Re: 38-7 bought today - by ekimetsok - 02-28-2011, 10:44 AM
Philco 91 Tuning Condenser
There are currently 5403 online users. [Complete List]
» 1 Member(s) | 5402 Guest(s)
