  • 2 Vote(s) - 4.5 Average
TrueTone Model D-2026 series B Manual
Find I am in need of some help. Bought a group of five radios. One that caught my eye and have begun working on is a TrueTone Model D2026 series B.
it is a 9 tube AM/FM radio. Problem is I am unable to find any resource for a manual.
Radiomuseum lists a D2026 series A which has the identical cabinet and controls. Problem is a D2026A is an 8 tube model.
Any suggestions would be welcome.
TrueTone Model D-2026 series B Manual - by TTech - 10-04-2020, 12:34 PM
Users browsing this thread: 15 Guest(s)
There are currently 9097 online users. [Complete List]
» 2 Member(s) | 9095 Guest(s)
