What model is this? Found one locally. 116B?
Not even close to 116B, though the year is the same.
It is a 630.
We could look at the grill.
But you might want to show the chassis also.
RE: What model is this? Found one locally. 116B? - by morzh - 10-08-2020, 07:06 PM
Eico 232 VTVM Schematic
There are currently 6498 online users. [Complete List]
» 1 Member(s) | 6497 Guest(s)
