What model is this? Found one locally. 116B?
That's the only two pics posted, he says it is that, but the 116b shows difference. Says it powers up, no reception, what would it be worth?
RE: What model is this? Found one locally. 116B? - by radio1 - 10-08-2020, 07:09 PM
Eico 232 VTVM Schematic
There are currently 7240 online users. [Complete List]
» 2 Member(s) | 7238 Guest(s)
