What model is this? Found one locally. 116B?
Dial bezel is on upside down...
RE: What model is this? Found one locally. 116B? - by Radioroslyn - 10-08-2020, 08:43 PM
There are currently 4706 online users. [Complete List]
» 1 Member(s) | 4705 Guest(s)
