Another aqusition a Model 20
Well have started replacing caps and rewinding the rf coils (one down two to go). This one is in a bit better condition than the model 21. Mostly just the secondaries are open on the coil and the driver transformer is good too.
Another aqusition a Model 20 - by 7estatdef - 02-26-2011, 07:00 PM
Re: Another aqusition - by TA Forbes - 02-27-2011, 01:00 AM
Re: Another aqusition - by 7estatdef - 02-27-2011, 09:31 AM
Re: Another aqusition - by TA Forbes - 02-27-2011, 02:07 PM
Re: Another aqusition - by 7estatdef - 02-27-2011, 03:26 PM
Re: Another aqusition - by 7estatdef - 02-28-2011, 09:15 PM
Re: Another aqusition - by 7estatdef - 02-28-2011, 10:22 PM
Re: Another aqusition - by 7estatdef - 03-01-2011, 09:22 AM
Re: Another aqusition - by 7estatdef - 03-01-2011, 11:01 PM
Re: Another aqusition a Model 20 - by 7estatdef - 03-02-2011, 11:06 PM
Re: Another aqusition a Model 20 - by Ron Ramirez - 03-03-2011, 08:48 AM
Re: Another aqusition a Model 20 - by 7estatdef - 03-17-2011, 05:51 PM
Re: Another aqusition a Model 20 - by codefox1 - 03-18-2011, 10:36 AM
Re: Another aqusition a Model 20 - by 7estatdef - 03-18-2011, 05:44 PM
Re: Another aqusition a Model 20 - by 7estatdef - 03-18-2011, 07:04 PM
Eico 232 VTVM Schematic
There are currently 9958 online users. [Complete List]
» 1 Member(s) | 9957 Guest(s)
