Grundig Majestic 8058
#52
The Photofact came today.
Yes, it is the American model.
The sch explains a few questions I had after using the German sch - it is quite different. Also much more clear the way it is drawn.
And it has the pictures and drawings, and alignment.
And it is original and clean and readable.
And! It is in English.
Many, many plusses.
Grundig Majestic 8058 - by morzh - 09-04-2020, 08:55 PM
RE: Grundig Majestic - by morzh - 09-04-2020, 09:16 PM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 03:53 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 04:03 AM
RE: Grundig Majestic - by morzh - 09-05-2020, 11:33 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 02:13 PM
RE: Grundig Majestic - by morzh - 09-05-2020, 02:39 PM
RE: Grundig Majestic - by RadioSvit - 09-06-2020, 11:04 AM
RE: Grundig Majestic - by morzh - 09-06-2020, 01:52 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 08:54 PM
RE: Grundig Majestic 8058 - by Phlogiston - 09-06-2020, 09:00 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 09:42 PM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 06:16 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:55 AM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 10:25 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 11:59 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:10 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 08:20 PM
RE: Grundig Majestic 8058 - by RodB - 09-08-2020, 08:57 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 09:36 PM
RE: Grundig Majestic 8058 - by morzh - 09-09-2020, 10:08 PM
RE: Grundig Majestic 8058 - by morzh - 09-10-2020, 09:53 PM
RE: Grundig Majestic 8058 - by morzh - 09-11-2020, 08:43 PM
RE: Grundig Majestic 8058 - by morzh - 09-12-2020, 10:18 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 07:05 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 08:22 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 09:32 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 10:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-17-2020, 10:54 PM
RE: Grundig Majestic 8058 - by morzh - 09-19-2020, 08:57 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 12:14 AM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 07:22 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 11:03 PM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 11:50 PM
RE: Grundig Majestic 8058 - by vecher - 09-24-2020, 12:10 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 08:39 AM
RE: Grundig Majestic 8058 - by rfeenstra - 09-24-2020, 09:49 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 11:37 AM
RE: Grundig Majestic 8058 - by morzh - 09-27-2020, 05:23 PM
RE: Grundig Majestic 8058 - by morzh - 09-29-2020, 09:42 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 04:19 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 05:38 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 09-30-2020, 05:47 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 08:18 PM
RE: Grundig Majestic 8058 - by Eliot Ness - 09-30-2020, 09:28 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 09:35 PM
RE: Grundig Majestic 8058 - by morzh - 10-01-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 05:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 11:55 PM
RE: Grundig Majestic 8058 - by morzh - 10-04-2020, 08:47 PM
RE: Grundig Majestic 8058 - by morzh - 10-10-2020, 01:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-11-2020, 07:50 PM
RE: Grundig Majestic 8058 - by morzh - 10-12-2020, 11:44 PM
RE: Grundig Majestic 8058 - by morzh - 10-13-2020, 11:28 PM
RE: Grundig Majestic 8058 - by morzh - 10-14-2020, 08:59 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 04:22 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 10-18-2020, 05:48 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 05:51 PM
RE: Grundig Majestic 8058 - by morzh - 10-20-2020, 02:38 PM
RE: Grundig Majestic 8058 - by morzh - 10-22-2020, 10:21 PM
RE: Grundig Majestic 8058 - by morzh - 10-27-2020, 09:42 PM
RE: Grundig Majestic 8058 - by morzh - 10-31-2020, 06:54 PM
RE: Grundig Majestic 8058 - by morzh - 11-04-2020, 07:00 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 08:14 PM
RE: Grundig Majestic 8058 - by vecher - 11-18-2020, 08:38 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 09:29 PM
RE: Grundig Majestic 8058 - by morzh - 12-06-2020, 09:57 PM
RE: Grundig Majestic 8058 - by morzh - 12-13-2020, 06:43 PM
RE: Grundig Majestic 8058 - by morzh - 12-23-2020, 09:07 PM
Eico 232 VTVM Schematic
There are currently 8316 online users. [Complete List]
» 2 Member(s) | 8314 Guest(s)
