  • 1 Vote(s) - 5 Average
Help!! I don’t know the model
Looks like a 60s model. I believe Philco used Voice of Music changers in the consoles. You probably have to take a closer look at the cartridge to match a needle. Quite often the original cartridge has been replaced.
Help!! I don’t know the model - by reegslee - 10-18-2020, 11:41 PM
RE: Help!! I don’t know the model - by RodB - 10-19-2020, 10:01 AM
RE: Help!! I don’t know the model - by Chas - 10-19-2020, 02:35 PM
There are currently 7890 online users. [Complete List]
» 2 Member(s) | 7888 Guest(s)
