Philco 45 "Butterfly"
it took a lot of work to get all the black off from the radio.  It appears that Philco used a stain to color the white wood and the plywood.  This is the cabinet stripped and sanded.  I need to glue some veneer to the shaped plywood for the the decorative pieces before I glue them to the radio.  I will experiment with some wiping stain on the cabinet to even out the color, then use toner to get the final color.  I believe I read somewhere Ron recommending the cabinet be toned with dark walnut toner and the decorative pieces with medium walnut.
Philco 45 "Butterfly" - by rfeenstra - 10-28-2020, 10:50 PM
RE: Philco 45 "Butterfly" - by morzh - 10-28-2020, 10:56 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-28-2020, 11:28 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 07:31 PM
RE: Philco 45 "Butterfly" - by morzh - 10-30-2020, 09:21 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 09:24 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 10:02 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-03-2020, 12:12 AM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-05-2020, 07:56 PM
RE: Philco 45 "Butterfly" - by Paul Philco322 - 11-05-2020, 08:23 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-05-2020, 10:24 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-06-2020, 12:34 AM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-06-2020, 02:40 AM
RE: Philco 45 "Butterfly" - by LarryFS - 11-06-2020, 11:03 AM
RE: Philco 45 "Butterfly" - by Paul Philco322 - 11-06-2020, 09:04 PM
RE: Philco 45 "Butterfly" - by Arran - 11-25-2020, 11:02 PM
