Philco 45 "Butterfly"
Thank you, Paul! I have redone the off white to a bit more yellow then "sprinkled" a bit of light walnut toner on it. Lacquer is drying now. I like it better but still may be a little too dominant. The original finish 45's I've seen on line have it more subdued. But, I can't keep putting lacquer on it! I think I'll live with it now. Pic will be coming.
Philco 45 "Butterfly" - by rfeenstra - 10-28-2020, 10:50 PM
RE: Philco 45 "Butterfly" - by morzh - 10-28-2020, 10:56 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-28-2020, 11:28 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 07:31 PM
RE: Philco 45 "Butterfly" - by morzh - 10-30-2020, 09:21 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 09:24 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 10-30-2020, 10:02 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-03-2020, 12:12 AM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-05-2020, 07:56 PM
RE: Philco 45 "Butterfly" - by Paul Philco322 - 11-05-2020, 08:23 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-05-2020, 10:24 PM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-06-2020, 12:34 AM
RE: Philco 45 "Butterfly" - by rfeenstra - 11-06-2020, 02:40 AM
RE: Philco 45 "Butterfly" - by LarryFS - 11-06-2020, 11:03 AM
RE: Philco 45 "Butterfly" - by Paul Philco322 - 11-06-2020, 09:04 PM
RE: Philco 45 "Butterfly" - by Arran - 11-25-2020, 11:02 PM
