Vol control with tap
Hello All.
I have a Firestone Model R-1661,
http://www.nostalgiaair.org/pagesbymodel...006273.pdf
The radio plays after restoration with the exception of the volume control ( #41A 250k ohm) which has some bad spots in it and I would like to replace it but the control has a Tap. Also the value of the pot is 500k so someone must have replaced it at one time.
Can I omit the tap?
Is there anyway to know the value of the tap or is it standard?
Is there a workaround I have a 250k pot I can use but it does not have a tap.
Thanks Eric
Vol control with tap - by Eric - 11-07-2020, 02:12 PM
RE: Vol control with tap - by OZ4 - 11-07-2020, 03:52 PM
RE: Vol control with tap - by radiorich - 11-08-2020, 02:56 AM
RE: Vol control with tap - by David - 11-08-2020, 09:25 AM
RE: Vol control with tap - by Eric - 11-08-2020, 11:52 AM
RE: Vol control with tap - by radiorich - 11-08-2020, 12:54 PM
91H Code 126 Restore
There are currently 4605 online users. [Complete List]
» 3 Member(s) | 4602 Guest(s)
