Magnavox Regency Symphony, 1947?
#72
Guys, I have some pertinent questions. Not sure of chassis number, but, I have a Maggy '46 model radio-phono.
It's in a nicely styled book case style case with two shelves.
Phono is in a drawer. 2 12" speakers are driven by pp 6L6 output tubes. Power trans. on same chassis. Has an eye tube, and, it's, I believe a 3 band radio. Two SW, one am.
Cabinet needs refinnishing, except for the lower shelf. It has a leatherette cover on cardboard covering the shelf, which has a mint finnish.
This set was dammaged by rats many years ago, but, radio sustained little dammage. Most dammage was to changer, which I have a correct replacement for.
I had re capped it long ago, but, still has original electrolytics.
It has a good eye tube in it.
At the time, the radio was playing well, as was rp.
I believe output tubes are now toast.
Is this set worth fixing?
I loved the sound at the time, but, it ia likwly it will now be expensive to finnish.
What do you guys say, and, if I should, can someone find me a good pair of 6L6G tubes?
I feel badly about the thing, and, would kind of like to see it going again, if it won't cost me an arm, and, a leg.
What do you think of the quality of these sets?
Bill Cahill
"If it lights in the dark and leaves you with a warm glow it's tubes."
"Honey, did you warm the baby bottle on my 75 watt hi-fi again?"
"I left it somewhere, but, where?"
Magnavox Regency Symphony, 1947? - by Ron Ramirez - 10-19-2010, 09:03 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:16 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 01:56 PM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:32 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-20-2010, 07:57 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-21-2010, 06:15 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-26-2010, 01:13 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-28-2010, 10:06 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 11-17-2010, 02:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-05-2010, 07:30 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-16-2010, 04:26 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 01-21-2011, 07:48 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 05:02 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 06:58 PM
Re: Magnavox Regency Symphony, 1947? - by PFJC2 - 02-06-2011, 10:08 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-07-2011, 10:16 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 12:18 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:39 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:16 AM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:54 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-25-2011, 07:23 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-03-2011, 10:45 PM
Re: Magnavox Regency Symphony, 1947? - by Bill Cahill - 03-04-2011, 01:44 AM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 05:29 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 09:30 PM
Eico 232 VTVM Schematic
There are currently 7502 online users. [Complete List]
» 1 Member(s) | 7501 Guest(s)
