Philco 37-84, code 121
Radioroslyn,
Question about the grounding. This chassis has the grounds connected to the chassis. The tube grounds are factory wired together and then to either a grounding lug or, for the tubes, connected to a socket rivet for grounding. This is the way I received it and it appears no mods were made to it since new.
So ... are you recommending I remove the grounds from the chassis and put them "above ground"?  Or leave them the way the factory originally installed them.
I now know the difference between an 84 and a 37-84. I am working on an 84.
John
Philco 37-84, code 121 - by Pa28rt201T - 11-03-2020, 07:40 PM
RE: Philco 37-84, code 121 - by klondike98 - 11-03-2020, 11:03 PM
RE: Philco 37-84, code 121 - by Pa28rt201T - 11-03-2020, 11:10 PM
RE: Philco 37-84, code 121 - by klondike98 - 11-03-2020, 11:14 PM
RE: Philco 37-84, code 121 - by klondike98 - 11-03-2020, 11:21 PM
RE: Philco 37-84, code 121 - by Pa28rt201T - 11-03-2020, 11:34 PM
RE: Philco 37-84, code 121 - by Radioroslyn - 11-04-2020, 12:42 PM
RE: Philco 37-84, code 121 - by falcon123 - 11-08-2020, 03:39 AM
RE: Philco 37-84, code 121 - by Pa28rt201T - 11-08-2020, 10:16 PM
RE: Philco 37-84, code 121 - by Radioroslyn - 11-08-2020, 10:44 PM
RE: Philco 37-84, code 121 - by klondike98 - 11-09-2020, 02:32 PM
More 37-84 - by Pa28rt201T - 11-03-2020, 08:02 PM
Schematic 37-84, code 121 - by Pa28rt201T - 11-07-2020, 01:09 AM
37-84 wiring - by Pa28rt201T - 11-07-2020, 09:59 PM
RE: 37-84 wiring - by Radioroslyn - 11-07-2020, 11:17 PM
RE: 37-84 wiring - by Pa28rt201T - 11-07-2020, 11:22 PM
RE: 37-84 wiring - by Radioroslyn - 11-07-2020, 11:30 PM
RE: 37-84 wiring - by Pa28rt201T - 11-08-2020, 10:18 PM
RE: 37-84 wiring - by Radioroslyn - 11-08-2020, 10:23 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4468 online users. [Complete List]
» 2 Member(s) | 4466 Guest(s)
