Magnavox Regency Symphony, 1947?
#73
Hi Bill
Sounds like you have a CR-194 chassis, that is what I have,in a different cabinet. They are good sounding radios. Does your have a short wave band, broadcast, Phono and FM on the selector. If it does my guess is that it is a CR-194 if it does not then it is most likely not. The one I have is a "Duette". I think it is worth fixing up the 6L6 tubes are sorta costly. I may have some here but they will be used. Hope this helps, look in Nostalgia under magnavox for CR-194 to see if it is yours ,
See Yea
Joe
Magnavox Regency Symphony, 1947? - by Ron Ramirez - 10-19-2010, 09:03 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:16 AM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 01:56 PM
Re: Magnavox Regency Symphony, 1947? - by denver - 10-19-2010, 09:32 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-20-2010, 07:57 PM
Re: Magnavox Regency Symphony, 1947? - by Jayce - 10-21-2010, 06:15 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-26-2010, 01:13 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 10-28-2010, 10:06 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 11-17-2010, 02:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-05-2010, 07:30 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 12-16-2010, 04:26 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 01-21-2011, 07:48 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 05:02 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-03-2011, 06:58 PM
Re: Magnavox Regency Symphony, 1947? - by PFJC2 - 02-06-2011, 10:08 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-07-2011, 10:16 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 12:18 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:37 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-09-2011, 03:39 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:16 AM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-10-2011, 12:54 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 02-25-2011, 07:23 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-03-2011, 10:45 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 05:29 PM
Re: Magnavox Regency Symphony, 1947? - by w4rtc - 03-04-2011, 09:30 PM
