Philco 53 701
I picked this little guy up very reasonable, nice and small maybe 12 inches across. Looks all original, couple of rust spots on chassis but not too bad. This is about what I have room for lately. Case solid with a bit of marbling should clean up OK.
https://www.flickr.com/photos/92577012@N...6846179721
Philco 53 701 - by Paul Philco322 - 11-11-2020, 07:11 PM
RE: Philco 53 701 - by klondike98 - 11-12-2020, 12:29 PM
RE: Philco 53 701 - by Paul Philco322 - 11-18-2020, 10:27 PM
There are currently 7833 online users. [Complete List]
» 2 Member(s) | 7831 Guest(s)
