Truetone D-726
I have other 80 tubes and I get the same, the more I look at the power side from the 42 through the 80 I'm seeing issues like the 5 pin (Cathode ) from the 42 is not going to chassis as the print shows but is routed through 2 resistors 250 ohms each I get 514 ohms total. The center tap which is supposed to go through a 250 ohm resistor is tied to the chassis directly. So I need to go through this line by line to see what they have done.
Truetone D-726 - by Eric - 11-11-2020, 12:15 PM
RE: Truetone D-726 - by RodB - 11-11-2020, 01:50 PM
RE: Truetone D-726 - by Radioroslyn - 11-11-2020, 02:12 PM
RE: Truetone D-726 - by Eric - 11-11-2020, 04:01 PM
RE: Truetone D-726 - by Radioroslyn - 11-11-2020, 07:25 PM
RE: Truetone D-726 - by RodB - 11-11-2020, 08:39 PM
RE: Truetone D-726 - by Eric - 11-12-2020, 11:19 AM
RE: Truetone D-726 - by RodB - 11-12-2020, 03:04 PM
RE: Truetone D-726 - by Eric - 11-16-2020, 02:09 PM
RE: Truetone D-726 - by RodB - 11-16-2020, 02:47 PM
RE: Truetone D-726 - by Eric - 11-16-2020, 04:54 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
