37-630 coil removal and repair.
I'll mention a couple of things. Not sure how you checked the coil (may have been thru the band switch). Would check the coil at it's connections  to be sure it's the issue. It could be a problem with bad bandswitch contacts. neither is a picnic.
36ga might be a bit of an over kill. Current wise something closer to 38-40ga would work and it would be shorter. 40ga =160' 160 ohms. 36ga is over 300'.
There is an alternative to rewinding that would be adding a rf choke from pins 1 and 2 and a small mica cap from pin 1 to 3.
37-630 coil removal and repair. - by Forrest - 11-12-2020, 12:43 PM
RE: 37-630 coil removal and repair. - by Radioroslyn - 11-12-2020, 01:55 PM
RE: 37-630 coil removal and repair. - by Forrest - 11-12-2020, 05:06 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4553 online users. [Complete List]
» 1 Member(s) | 4552 Guest(s)
