Thalia & Melpomene
Thanks for sharing those with us.
That is one heck of a 25hz transformer on the 555-5 chassis!
Thalia & Melpomene - by Phlogiston - 11-17-2020, 04:09 PM
RE: Thalia & Melpomene - by Eliot Ness - 11-18-2020, 09:15 AM
RE: Thalia & Melpomene - by Ron Ramirez - 11-18-2020, 10:32 AM
RE: Thalia & Melpomene - by morzh - 11-18-2020, 12:12 PM
The speaker table error?
Philco 70 antenna lead
