Grundig Majestic 8058
#65
Today the EM34 tube I ordered from eBay came. The guy who was selling it was in Belgium and the price was way better than the rest, mere $70 plus shipping which still came about $87 tax included.
Today I heard a loud knock on the door: the international shipping guy was holding in hand a really smashed box. He asked me if I wanted it 'cause it was really dented. I looked at the size of the box, and it was way oversized so I figured it was not likely the tube if packed well would be damaged from this dent. I accepted the box, photographed it, sprayed it with disinfectant and let it sit awhile before opening it. When I opened it I realized the box was very soft - the outside was mere wrapping brown paper so it was not, strictly speaking, a box, and the rest inside was a lot of bubble wrap - not a bad packing for a single tube.
I have just tested it as Hickok described - it involves connecting 1M resistors from the Plate jack to the pins 3 and 6 of Loctal socket which are in parallel to the same pins in the Octal one; the tube exhibited bright key-lime-green glow with both sectors closing when said by the manual.
So, I have a new bright tube. Again the old one seems to work, just not as bright but still kinda acceptable.
I received the idler wheel from Gary Stork yesterday; I installed it and it became much better. There was still some rumbling but I figured it was not coming from the idler and was exacerbated by the turntable being on the bench - once I put felt pads under the points of it touching the table the rumbling became very low. Still I thought there (as described by the SAMS) might be a problem with the bearing balls. I tried to take it out and the balls started falling out. I have not lost any, but one ball felt a bit uneven, though that could've been my fingers with the guitar playing damage. So I ordered 2mm balls of G10 grading (seems like to get better one i have to go to ceramic ones; I think it is fine) and as long as I am at it I will try to replace it. Not a simple task without fully taking apart the bottom of the player which so far was not in the plans. I also need to order the grease - I am not sure Lithium is good for it, plus regular grease holds the balls in place better. They should come tomorrow.
Will see.
Grundig Majestic 8058 - by morzh - 09-04-2020, 08:55 PM
RE: Grundig Majestic - by morzh - 09-04-2020, 09:16 PM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 03:53 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 04:03 AM
RE: Grundig Majestic - by morzh - 09-05-2020, 11:33 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 02:13 PM
RE: Grundig Majestic - by morzh - 09-05-2020, 02:39 PM
RE: Grundig Majestic - by RadioSvit - 09-06-2020, 11:04 AM
RE: Grundig Majestic - by morzh - 09-06-2020, 01:52 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 08:54 PM
RE: Grundig Majestic 8058 - by Phlogiston - 09-06-2020, 09:00 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 09:42 PM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 06:16 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:55 AM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 10:25 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 11:59 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:10 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 08:20 PM
RE: Grundig Majestic 8058 - by RodB - 09-08-2020, 08:57 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 09:36 PM
RE: Grundig Majestic 8058 - by morzh - 09-09-2020, 10:08 PM
RE: Grundig Majestic 8058 - by morzh - 09-10-2020, 09:53 PM
RE: Grundig Majestic 8058 - by morzh - 09-11-2020, 08:43 PM
RE: Grundig Majestic 8058 - by morzh - 09-12-2020, 10:18 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 07:05 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 08:22 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 09:32 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 10:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-17-2020, 10:54 PM
RE: Grundig Majestic 8058 - by morzh - 09-19-2020, 08:57 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 12:14 AM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 07:22 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 11:03 PM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 11:50 PM
RE: Grundig Majestic 8058 - by vecher - 09-24-2020, 12:10 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 08:39 AM
RE: Grundig Majestic 8058 - by rfeenstra - 09-24-2020, 09:49 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 11:37 AM
RE: Grundig Majestic 8058 - by morzh - 09-27-2020, 05:23 PM
RE: Grundig Majestic 8058 - by morzh - 09-29-2020, 09:42 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 04:19 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 05:38 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 09-30-2020, 05:47 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 08:18 PM
RE: Grundig Majestic 8058 - by Eliot Ness - 09-30-2020, 09:28 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 09:35 PM
RE: Grundig Majestic 8058 - by morzh - 10-01-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 05:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 11:55 PM
RE: Grundig Majestic 8058 - by morzh - 10-04-2020, 08:47 PM
RE: Grundig Majestic 8058 - by morzh - 10-10-2020, 01:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-11-2020, 07:50 PM
RE: Grundig Majestic 8058 - by morzh - 10-12-2020, 11:44 PM
RE: Grundig Majestic 8058 - by morzh - 10-13-2020, 11:28 PM
RE: Grundig Majestic 8058 - by morzh - 10-14-2020, 08:59 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 04:22 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 10-18-2020, 05:48 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 05:51 PM
RE: Grundig Majestic 8058 - by morzh - 10-20-2020, 02:38 PM
RE: Grundig Majestic 8058 - by morzh - 10-22-2020, 10:21 PM
RE: Grundig Majestic 8058 - by morzh - 10-27-2020, 09:42 PM
RE: Grundig Majestic 8058 - by morzh - 10-31-2020, 06:54 PM
RE: Grundig Majestic 8058 - by morzh - 11-04-2020, 07:00 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 08:14 PM
RE: Grundig Majestic 8058 - by vecher - 11-18-2020, 08:38 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 09:29 PM
RE: Grundig Majestic 8058 - by morzh - 12-06-2020, 09:57 PM
RE: Grundig Majestic 8058 - by morzh - 12-13-2020, 06:43 PM
RE: Grundig Majestic 8058 - by morzh - 12-23-2020, 09:07 PM
Eico 232 VTVM Schematic
There are currently 9051 online users. [Complete List]
» 1 Member(s) | 9050 Guest(s)
