model 53-956 ... from a generous friend
Trying to find out what type dial lamps the 53-956 takes.
Any help would be appreciated.
Rick
RE: model 53-956 ... from a generous friend - by Rick Clark - 11-22-2020, 03:06 PM
There are currently 9771 online users. [Complete List]
» 1 Member(s) | 9770 Guest(s)
