model 53-956 ... from a generous friend
Hi Rick,
According to the service info in the Philco Library:
https://philcoradio.com/library/index.ph...year-book/
it's a 7W frosted lamp. Philco part 34-2605. I believe that's essentially the same form factor as a C-7 Christmas tree light or night light.
Something like this might work: https://www.amazon.com/Sunlite-7C7-WH-CD...B007RL08AC
RE: model 53-956 ... from a generous friend - by Nathan Slingerland - 11-22-2020, 03:15 PM
There are currently 3673 online users. [Complete List]
» 1 Member(s) | 3672 Guest(s)
