model 53-956 ... from a generous friend
If it uses one of those C7 bulbs, I would use an LED replacement instead of an incandescent - less heat.
RE: model 53-956 ... from a generous friend - by Ron Ramirez - 11-22-2020, 11:01 PM
There are currently 10886 online users. [Complete List]
» 2 Member(s) | 10884 Guest(s)
