"New" Philco
I agree with Terry. Just guessing, it's probably no older than 1959 or 1960.
"New" Philco - by DannyHatfield - 03-05-2011, 04:13 AM
Re: "New" Philco - by 7estatdef - 03-05-2011, 06:23 PM
Re: "New" Philco - by Ron Ramirez - 03-05-2011, 06:24 PM
Re: "New" Philco - by DannyHatfield - 03-05-2011, 11:51 PM
There are currently 8563 online users. [Complete List]
» 1 Member(s) | 8562 Guest(s)
