Keep us posted, Russ, on what you find. I, too, am working on a H500 with the same tube so I'm hoping all works well. I have also read about some of the problems with this tube. My radio (see November finds) was working an all bands before I disassembled to rebuild. The radio had been worked on previously. The selenium was bridged with a silicone diode with no extra resistor added. I assume the tubes were running a bit higher filament and operating voltage - probably not good for these somewhat fragile tubes.. I'll be interested in what you find.
1L6 - by Phlogiston - 11-24-2020, 03:24 PM
RE: 1L6 - by rfeenstra - 11-24-2020, 03:32 PM
RE: 1L6 - by Chas - 11-24-2020, 03:52 PM
RE: 1L6 - by Phlogiston - 11-24-2020, 06:11 PM
RE: 1L6 - by Paul Philco322 - 11-24-2020, 06:55 PM
RE: 1L6 - by Phlogiston - 11-24-2020, 06:57 PM
RE: 1L6 - by rfeenstra - 11-24-2020, 11:20 PM
RE: 1L6 - by 462ron - 11-25-2020, 10:26 AM
RE: 1L6 - by captainclock1988 - 11-25-2020, 05:33 PM
RE: 1L6 - by Phlogiston - 11-25-2020, 06:51 PM
RE: 1L6 - by Arran - 11-25-2020, 10:45 PM
RE: 1L6 - by Phlogiston - 11-26-2020, 11:58 AM
RE: 1L6 - by Arran - 11-27-2020, 03:22 AM
RE: 1L6 - by Phlogiston - 11-27-2020, 01:41 PM
RE: 1L6 - by Phlogiston - 12-05-2020, 12:00 PM
RE: 1L6 - by rfeenstra - 12-05-2020, 02:35 PM
RE: 1L6 - by Phlogiston - 12-05-2020, 02:49 PM
RE: 1L6 - by Phlogiston - 01-23-2021, 12:11 PM
There are currently 8318 online users. [Complete List]
» 2 Member(s) | 8316 Guest(s)
