Can I use a rooftop TV antenna with my Philco radio?
Yes. the inner wire is shielded, but I've had pretty good luck using the shield as an AM antenna. Simply making contact with the metal connector will connect your radio antenna lead with the coax outer shield.
AM 1530 Riverside Radio (my home AMT3000 station)
Re: Can I use a rooftop TV antenna with my Philco radio? - by jepstr67 - 03-05-2011, 07:37 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6772 online users. [Complete List]
» 4 Member(s) | 6768 Guest(s)
AvatarAvatarAvatarAvatar
