1937 Coronado Model 650 Farm Radio
Hi;
  With regard to the original poster's question about battery voltages I thought I should interject. In most battery operated radios of the 1930s, up until the advent of "low current" battery types that debut around 1939 or so, the standard filament voltage was 2 volts, as that was approximately the voltage of one cell of a lead-acid wet cell battery. Do not run 2 volt battery tubes at 2.5 volts, or they will not live too long, they won't instantly burn out, but they won't last long either. I think you could find a 2 volt rechargeable battery, otherwise you could use two 1.5 volt batteries, in series, with a diode to drop it down somewhat, under load it should be pretty close for testing purposes. Building a proper battery eliminator should be the long term plan, there was a reason why they never really made many battery portables prior to the war years, it was not very practical thanks to filament current consumption.
  I don't know whom actually manufactured sets for Gamble-Skogmo, but it may have been Continental Radio & TV (Admiral), however Riders has them listed under Gamble-Skogmo so that's where the service information is to be found.
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 05:43 PM
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 06:03 PM
RE: 1930s Coronado Farm Radio - by David - 11-25-2020, 06:56 PM
RE: 1930s Coronado Farm Radio - by Arran - 11-25-2020, 10:36 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-25-2020, 11:48 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 10:00 AM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 01:02 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 03:56 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-27-2020, 03:03 AM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-28-2020, 04:30 AM
RE: 1937 Coronado Model 650 Farm Radio - by RodB - 01-01-2021, 10:16 AM
RE: 1937 Coronado Model 650 Farm Radio - by David - 01-08-2021, 09:11 PM
There are currently 5754 online users. [Complete List]
» 2 Member(s) | 5752 Guest(s)
