1937 Coronado Model 650 Farm Radio
Couple of options first a 12volt battery. https://www.amazon.com/Miady-Phosphate-R...282&sr=1-9    The second if money is no object.  https://www.amazon.com/Jackery-Portable-...V5A9DKT3PS   Have the jackery 240 nice piece of equipment great for car camping. I can power my radios at the house without having to run the generator during a power outage..
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 05:43 PM
RE: 1930s Coronado Farm Radio - by Eliot Ness - 11-25-2020, 06:03 PM
RE: 1930s Coronado Farm Radio - by David - 11-25-2020, 06:56 PM
RE: 1930s Coronado Farm Radio - by Arran - 11-25-2020, 10:36 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-25-2020, 11:48 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 10:00 AM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 01:02 PM
RE: 1937 Coronado Model 650 Farm Radio - by David - 11-26-2020, 03:56 PM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-27-2020, 03:03 AM
RE: 1937 Coronado Model 650 Farm Radio - by Arran - 11-28-2020, 04:30 AM
RE: 1937 Coronado Model 650 Farm Radio - by RodB - 01-01-2021, 10:16 AM
RE: 1937 Coronado Model 650 Farm Radio - by David - 01-08-2021, 09:11 PM
Philco 91 Tuning Condenser
There are currently 8317 online users. [Complete List]
» 2 Member(s) | 8315 Guest(s)
