Unknown Tubes on a 42-327
regel_1999 Wrote:My dilemma is this: Do I take the whole d**n radio apart, rewire everything and put it all back together (something I'm terribly confident I can do well) or do I use the radio as parts and find another old radio?
No, and no!
I was thinking about something last night. The 42-327 requires a loop antenna. Is the loop antenna present, and connected, on your radio? If it is missing, or not connected, it could cause buzzing.
Forget about grounds. This being an AC/DC set, you do not want to ground the chassis at all, period.
What did you touch when you received the shock? You should not have received a shock from the chassis. If you did, something is miswired.
The Philco AC/DC sets of this era have the chassis isolated from B- (one side of the AC line) with a resistor and a capacitor, as I recall.
Where in Ohio are you located? I think you could use someone close by to help you out.
Finally, exactly where are you measuring 170 volts DC? Can you show a picture? You should not have that kind of voltage in this set at all.
Unknown Tubes on a 42-327 - by regel_1999 - 03-04-2011, 11:23 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-05-2011, 11:31 AM
Re: Unknown Tubes on a 42-327 - by Carl Travis - 03-05-2011, 11:44 AM
Re: Unknown Tubes on a 42-327 - by BILL - 03-05-2011, 01:46 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-05-2011, 03:28 PM
42-327 with grounds - by regel_1999 - 03-06-2011, 03:19 PM
Re: 42-327 with grounds - by Ron Ramirez - 03-06-2011, 03:45 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 07:26 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-06-2011, 07:51 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:06 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-06-2011, 08:35 PM
Re: Unknown Tubes on a 42-327 - by DeckApe - 03-07-2011, 02:11 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-07-2011, 09:50 AM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-07-2011, 10:45 AM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-07-2011, 11:24 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-08-2011, 12:49 PM
Re: Unknown Tubes on a 42-327 - by Glenn Roberts - 03-08-2011, 04:38 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-08-2011, 04:46 PM
Re: Unknown Tubes on a 42-327 - by 7estatdef - 03-09-2011, 05:52 PM
Re: Unknown Tubes on a 42-327 - by Ed Locker - 03-10-2011, 10:03 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-10-2011, 07:29 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-14-2011, 12:36 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-14-2011, 10:09 AM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-16-2011, 02:47 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-16-2011, 06:09 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-16-2011, 10:15 PM
Re: Unknown Tubes on a 42-327 - by Ron Ramirez - 03-17-2011, 11:38 AM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 12:08 PM
Re: Unknown Tubes on a 42-327 - by rplackey - 03-17-2011, 01:32 PM
Re: Unknown Tubes on a 42-327 - by regel_1999 - 03-17-2011, 08:39 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5011 online users. [Complete List]
» 3 Member(s) | 5008 Guest(s)
