Stewart Warner 9001-F
A couple of things come to mind. Check bypass caps around the mixer and IF amp also lead dress. If that seems OK then realign rf and IF stages and you may find that detuning the IF slightly will make it disappear.
Stewart Warner 9001-F - by Tucker - 11-29-2020, 01:31 PM
RE: Stewart Warner 9001-F - by Radioroslyn - 11-29-2020, 02:07 PM
RE: Stewart Warner 9001-F - by Arran - 11-30-2020, 06:52 PM
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4873 online users. [Complete List]
» 2 Member(s) | 4871 Guest(s)
