What is this mess?
Regarding the third version 90:
Yes, they went to push-pull 47 outputs which is nice, but they cheapened the front end by getting rid of the separate oscillator tube and adopting the "autodyne" circuit; i.e. using a single 24 as mixer and oscillator. A poor design then, an even poorer design now. Ask anyone who owns a Philco 89 or 19.
What is this mess? - by OldRestorer - 11-28-2020, 09:46 PM
RE: What is this mess? - by KCMike - 11-28-2020, 10:26 PM
RE: What is this mess? - by Ron Ramirez - 11-28-2020, 10:44 PM
RE: What is this mess? - by OldRestorer - 11-28-2020, 11:32 PM
RE: What is this mess? - by morzh - 11-29-2020, 12:53 PM
RE: What is this mess? - by radiorich - 11-29-2020, 01:21 PM
RE: What is this mess? - by radio1 - 11-29-2020, 10:30 PM
RE: What is this mess? - by radiorich - 11-29-2020, 10:37 PM
RE: What is this mess? - by Ron Ramirez - 11-29-2020, 11:37 PM
RE: What is this mess? - by Steve Davis - 11-29-2020, 11:45 PM
Philco 91 Tuning Condenser
