48-230 Antenna Loop
I replaced #20, a little better.   Also, #25 was over 300 Ohms, replaced it.
Pin 5, strong negative voltage and I put on a 3M resistor and the voltage dropped some and that station was clear as a bell.  BUT - Everything else on the dial was distorted.   Something going on with the 14B6 diode?
48-230 Antenna Loop - by Daniel Bingamon - 11-13-2020, 09:24 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 11-14-2020, 01:34 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-14-2020, 07:11 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-14-2020, 07:50 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 11-15-2020, 12:27 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-15-2020, 09:38 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-15-2020, 10:06 AM
RE: 48-230 Antenna Loop - by RodB - 11-15-2020, 12:09 PM
RE: 48-230 Antenna Loop - by morzh - 11-15-2020, 12:30 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 11-15-2020, 01:18 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-15-2020, 02:25 PM
RE: 48-230 Antenna Loop - by RodB - 11-15-2020, 02:44 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-24-2020, 09:54 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-25-2020, 12:19 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-27-2020, 08:04 PM
RE: 48-230 Antenna Loop - by klondike98 - 11-29-2020, 09:40 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-29-2020, 10:30 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 11-30-2020, 11:34 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 11-30-2020, 09:08 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 12-01-2020, 12:32 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-02-2020, 09:34 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-02-2020, 11:42 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 12-02-2020, 11:50 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-03-2020, 08:14 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-03-2020, 08:31 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 12-03-2020, 11:53 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-04-2020, 08:03 AM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-04-2020, 08:18 PM
RE: 48-230 Antenna Loop - by Daniel Bingamon - 12-06-2020, 06:23 PM
RE: 48-230 Antenna Loop - by Radioroslyn - 12-06-2020, 08:17 PM
48-230 Weak Signal - by Daniel Bingamon - 11-29-2020, 08:43 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 2718 online users. [Complete List]
» 1 Member(s) | 2717 Guest(s)
