Hammond Output Transformer Feedback Loop Workaround
The center tap on the primary side isn't going to do you any good for feedback as there is no audio present at that point just HV. The feedback loop will have to be connected to the secondary. I would just experiment with the different taps till you find something you like. I'm assuming that the transformer has a multi tap secondary. If it oscillates (squeals) reverse the connections. That's called positive regeneration what you want negative feedback or negative regeneration.
Good luck!
Re: Hammond Output Transformer Feedback Loop Workaround - by 7estatdef - 03-07-2011, 08:21 PM
Philco 89 indicator light.
There are currently 8269 online users. [Complete List]
» 2 Member(s) | 8267 Guest(s)
