Test power supply build
Thanks for the input guys. I found a big ole transformer from a mid 50's Admiral TV. Got lots of current, lots of voltage and a really cool rectifier tube socket right on top. I might save this one for an amp project tho. It's really neat looking. She was putting out 600v dc off the rectifier output with a filter cap clipped on. No load. I could use a separate trans for tube filaments and run direct, with the B+ run off a small variac. Be heavy tho. Probably be a built in part of my service bench. Future project...
Tim
Test power supply build - by TV MAN - 10-27-2020, 12:22 PM
RE: Test power supply build - by Chas - 10-27-2020, 02:14 PM
RE: Test power supply build - by TV MAN - 10-29-2020, 12:17 AM
RE: Test power supply build - by Chas - 10-29-2020, 11:22 AM
RE: Test power supply build - by TV MAN - 10-29-2020, 12:26 PM
RE: Test power supply build - by TV MAN - 10-29-2020, 12:43 PM
RE: Test power supply build - by TV MAN - 11-22-2020, 05:19 PM
RE: Test power supply build - by morzh - 11-22-2020, 06:03 PM
RE: Test power supply build - by Phlogiston - 11-22-2020, 06:57 PM
RE: Test power supply build - by TV MAN - 12-03-2020, 10:47 PM
RE: Test power supply build - by TV MAN - 12-03-2020, 11:29 PM
Eico 232 VTVM Schematic
There are currently 6691 online users. [Complete List]
» 3 Member(s) | 6688 Guest(s)
