38-116 dial replacement
i did a search on the site and did not see anything so can someone tell me how to replace the dial on a 38-116 are there any phots out there
benny
38-116 dial replacement - by mg34.42 - 12-07-2020, 11:13 PM
RE: 38-116 dial replacement - by Radioroslyn - 12-08-2020, 12:20 AM
RE: 38-116 dial replacement - by rfeenstra - 12-08-2020, 01:23 AM
RE: 38-116 dial replacement - by 462ron - 12-08-2020, 12:12 PM
RE: 38-116 dial replacement - by mg34.42 - 12-08-2020, 11:52 PM
Philco 91 Tuning Condenser
There are currently 8653 online users. [Complete List]
» 3 Member(s) | 8650 Guest(s)
