38-116 dial replacement
Benny, give this link a look see. It’s from the Philco Repair Bench website and has a detailed view and instructions on the 37-116 mechanism which should be close to what you’re looking for!
https://www.philcorepairbench.com/wp-con...ervice.pdf
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
38-116 dial replacement - by mg34.42 - 12-07-2020, 11:13 PM
RE: 38-116 dial replacement - by Radioroslyn - 12-08-2020, 12:20 AM
RE: 38-116 dial replacement - by rfeenstra - 12-08-2020, 01:23 AM
RE: 38-116 dial replacement - by 462ron - 12-08-2020, 12:12 PM
RE: 38-116 dial replacement - by mg34.42 - 12-08-2020, 11:52 PM
Philco 91 Tuning Condenser
There are currently 8856 online users. [Complete List]
» 3 Member(s) | 8853 Guest(s)
