3D Print Transitone Flying Dart Face
It's been updated. I also tried to load it into Slic3r and it shows correctly. Also, it has been scaled so that the width is ever so slightly larger that the chassis width. You should be able to scale it as you like from there.
RE: 3D Print Transitone Flying Dart Face - by Daniel Bingamon - 12-09-2020, 08:59 PM
