Zenith 6D015 Antenna ?
Good Morning!
I have a Zenith 6D015 with a missing loop antenna. Here is the info.
http://www.nostalgiaair.org/pagesbymodel...025061.pdf
I want to make a loop to improve reception which is not that bad but still I would like to improve it.
My questions are on the schematic for the loop shows a wire marked A (antenna) & G (ground)? Does this wire in any way connect to the chassis? It shows just looping the antenna loop. Am I looking at it correctly?
Thanks
Eric
Zenith 6D015 Antenna ? - by Eric - 12-10-2020, 10:51 AM
RE: Zenith 6D015 Antenna ? - by Eliot Ness - 12-10-2020, 11:24 AM
RE: Zenith 6D015 Antenna ? - by Eric - 12-10-2020, 12:13 PM
RE: Zenith 6D015 Antenna ? - by Eliot Ness - 12-10-2020, 07:32 PM
RE: Zenith 6D015 Antenna ? - by Chas - 12-10-2020, 09:11 PM
RE: Zenith 6D015 Antenna ? - by Eric - 12-11-2020, 11:31 AM
RE: Zenith 6D015 Antenna ? - by Chas - 12-11-2020, 12:48 PM
There are currently 10048 online users. [Complete List]
» 2 Member(s) | 10046 Guest(s)
