Grundig Majestic 8058
#69
Well, I concocted the slipmat.
Here it is:
I cut the bottom for the lower part of the centerpiece and cut the upper with wider circle and the tabs for the upper part.
Not ideal but it worked.
Then I installed 33-1/3 rpm Pfanstiehl stylus, put the changer in the setr, put a record of 1930 dance music on, and turned it on.
It played VERY well.
I still have some mechanical issues of the tonearm not automatically coming to the start of the record, so it goes back but does not turn off by itself and at this point I can manually position the tonearm to the record.
Well, I have the SAMS so I will try to align it. Anyone with experience - some advice is welcome.
I have a video that shows the record and the radio playing, but as I no longer am on the Youtube, I am not sure how to show it here.
BTW, the BC plays marvelously with this radio. I am sure the local "Jersey Shore" station uses the HiFi wide band, but I never got this sound out anything including 38-690.  Maybe the equalizer is the reason.
Grundig Majestic 8058 - by morzh - 09-04-2020, 08:55 PM
RE: Grundig Majestic - by morzh - 09-04-2020, 09:16 PM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 03:53 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 04:03 AM
RE: Grundig Majestic - by morzh - 09-05-2020, 11:33 AM
RE: Grundig Majestic - by RadioSvit - 09-05-2020, 02:13 PM
RE: Grundig Majestic - by morzh - 09-05-2020, 02:39 PM
RE: Grundig Majestic - by RadioSvit - 09-06-2020, 11:04 AM
RE: Grundig Majestic - by morzh - 09-06-2020, 01:52 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 08:54 PM
RE: Grundig Majestic 8058 - by Phlogiston - 09-06-2020, 09:00 PM
RE: Grundig Majestic 8058 - by morzh - 09-06-2020, 09:42 PM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 06:16 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:55 AM
RE: Grundig Majestic 8058 - by RadioSvit - 09-07-2020, 10:25 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 11:59 AM
RE: Grundig Majestic 8058 - by morzh - 09-07-2020, 09:10 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 08:20 PM
RE: Grundig Majestic 8058 - by RodB - 09-08-2020, 08:57 PM
RE: Grundig Majestic 8058 - by morzh - 09-08-2020, 09:36 PM
RE: Grundig Majestic 8058 - by morzh - 09-09-2020, 10:08 PM
RE: Grundig Majestic 8058 - by morzh - 09-10-2020, 09:53 PM
RE: Grundig Majestic 8058 - by morzh - 09-11-2020, 08:43 PM
RE: Grundig Majestic 8058 - by morzh - 09-12-2020, 10:18 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 07:05 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 08:22 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 09:32 PM
RE: Grundig Majestic 8058 - by vecher - 09-13-2020, 10:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-13-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 09-17-2020, 10:54 PM
RE: Grundig Majestic 8058 - by morzh - 09-19-2020, 08:57 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 12:14 AM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 07:22 PM
RE: Grundig Majestic 8058 - by vecher - 09-23-2020, 11:03 PM
RE: Grundig Majestic 8058 - by morzh - 09-23-2020, 11:50 PM
RE: Grundig Majestic 8058 - by vecher - 09-24-2020, 12:10 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 08:39 AM
RE: Grundig Majestic 8058 - by rfeenstra - 09-24-2020, 09:49 AM
RE: Grundig Majestic 8058 - by morzh - 09-24-2020, 11:37 AM
RE: Grundig Majestic 8058 - by morzh - 09-27-2020, 05:23 PM
RE: Grundig Majestic 8058 - by morzh - 09-29-2020, 09:42 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 04:19 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 05:38 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 09-30-2020, 05:47 PM
RE: Grundig Majestic 8058 - by morzh - 09-30-2020, 08:18 PM
RE: Grundig Majestic 8058 - by Eliot Ness - 09-30-2020, 09:28 PM
RE: Grundig Majestic 8058 - by radiohenry - 09-30-2020, 09:35 PM
RE: Grundig Majestic 8058 - by morzh - 10-01-2020, 11:24 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 05:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-03-2020, 11:55 PM
RE: Grundig Majestic 8058 - by morzh - 10-04-2020, 08:47 PM
RE: Grundig Majestic 8058 - by morzh - 10-10-2020, 01:49 PM
RE: Grundig Majestic 8058 - by morzh - 10-11-2020, 07:50 PM
RE: Grundig Majestic 8058 - by morzh - 10-12-2020, 11:44 PM
RE: Grundig Majestic 8058 - by morzh - 10-13-2020, 11:28 PM
RE: Grundig Majestic 8058 - by morzh - 10-14-2020, 08:59 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 04:22 PM
RE: Grundig Majestic 8058 - by Paul Philco322 - 10-18-2020, 05:48 PM
RE: Grundig Majestic 8058 - by morzh - 10-18-2020, 05:51 PM
RE: Grundig Majestic 8058 - by morzh - 10-20-2020, 02:38 PM
RE: Grundig Majestic 8058 - by morzh - 10-22-2020, 10:21 PM
RE: Grundig Majestic 8058 - by morzh - 10-27-2020, 09:42 PM
RE: Grundig Majestic 8058 - by morzh - 10-31-2020, 06:54 PM
RE: Grundig Majestic 8058 - by morzh - 11-04-2020, 07:00 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 08:14 PM
RE: Grundig Majestic 8058 - by vecher - 11-18-2020, 08:38 PM
RE: Grundig Majestic 8058 - by morzh - 11-18-2020, 09:29 PM
RE: Grundig Majestic 8058 - by morzh - 12-06-2020, 09:57 PM
RE: Grundig Majestic 8058 - by morzh - 12-13-2020, 06:43 PM
RE: Grundig Majestic 8058 - by morzh - 12-23-2020, 09:07 PM
Eico 232 VTVM Schematic
There are currently 8734 online users. [Complete List]
» 2 Member(s) | 8732 Guest(s)
