40-155 Unusual buzzing
Hi Mike,
Welcome.
Does this buzz disappear when you turn the AC plug around 180 degrees?
One set I had I did not change one cap out because it looked like a large mica. It was a bypass cap , which was still a paper/foil in a bakelite casing. CHanged it out and the buzz went away.
Have you checked the volume control for any 'opens' along it's travel. Another set I had that buzzed, not hum, and turned ot to be a break or wore down carbon inside the volume control.
Good luck.
Gary
40-155 Unusual buzzing - by Guest - 03-14-2006, 12:22 PM
[No subject] - by Chuck Schwark - 03-14-2006, 01:52 PM
[No subject] - by Guest - 03-14-2006, 04:19 PM
[No subject] - by Chuck Schwark - 03-14-2006, 04:39 PM
[No subject] - by gary rabbitt - 03-23-2006, 02:19 PM
