Motorola 77FM
All, I have a bad Silicon rectifier.. will replace with a 1N5408.. Question is do I need any additional resistance after the diode?
Here is schematic
[Image: https://live.staticflickr.com/65535/5072...5bf7_c.jpg]
Thanks
Skip
Motorola 77FM - by vecher - 12-16-2020, 05:23 PM
RE: Motorola 77FM - by Phlogiston - 12-16-2020, 05:44 PM
RE: Motorola 77FM - by Chas - 12-16-2020, 05:52 PM
RE: Motorola 77FM - by RodB - 12-16-2020, 05:58 PM
