Atwater Kent 84 - Value?
I would want to know the condition of the power transformer first, A.K used to use rubber wire leads on them, which breaks down, and can cause shorts. If it smells burned I wouldn't pay more then $100 for it.
Atwater Kent 84 - Value? - by Allen in SB - 12-19-2020, 12:48 AM
RE: Atwater Kent 84 - Value? - by Arran - 12-19-2020, 05:01 AM
RE: Atwater Kent 84 - Value? - by Eliot Ness - 12-19-2020, 02:17 PM
RE: Atwater Kent 84 - Value? - by Phlogiston - 12-19-2020, 02:59 PM
RE: Atwater Kent 84 - Value? - by morzh - 12-19-2020, 06:37 PM
RE: Atwater Kent 84 - Value? - by Allen in SB - 12-20-2020, 12:39 AM
RE: Atwater Kent 84 - Value? - by Arran - 12-20-2020, 03:21 AM
There are currently 10591 online users. [Complete List]
» 1 Member(s) | 10590 Guest(s)
