35-1285 Record Changer Repair
I have finally gotten all of the rubber parts on the record changer either replaced or repaired.  I am starting to reassemble everything and find that the Trunnion Assembly (part number 35-2604) seems to be missing the rubber bushings , or whatever keeps the bottom shaft bearing from flopping around.
I have the factory service manual, but the pictures of that part don't show enough detail to tell what's missing.  I also have another complete changer, but the Trunnion Assembly looks just the same - like a rubber bushing (or at least some kind of bushing) is missing.  The holes in the bracket are much larger than the pin that goes through the bearing.
Does someone have a working BOL changer?  If so, can you tell me how the Trunnion Assembly is put together?
I've attached a drawing of the assembly.
35-1285 Record Changer Repair - by R. Ramjet - 05-15-2019, 11:15 AM
RE: 35-1285 Record Changer Repair - by klondike98 - 05-15-2019, 06:50 PM
RE: 35-1285 Record Changer Repair - by morzh - 05-15-2019, 07:11 PM
RE: 35-1285 Record Changer Repair - by Jake Blake - 05-15-2019, 08:16 PM
RE: 35-1285 Record Changer Repair - by R. Ramjet - 05-16-2019, 11:26 AM
RE: 35-1285 Record Changer Repair - by R. Ramjet - 05-16-2019, 11:28 AM
RE: 35-1285 Record Changer Repair - by Jake Blake - 05-17-2019, 01:52 PM
RE: 35-1285 Record Changer Repair - by sam - 05-27-2019, 06:53 PM
RE: 35-1285 Record Changer Repair - by Jake Blake - 05-27-2019, 09:59 PM
RE: 35-1285 Record Changer Repair - by R. Ramjet - 05-27-2019, 10:29 PM
RE: 35-1285 Record Changer Repair - by R. Ramjet - 05-28-2019, 11:52 AM
RE: 35-1285 Record Changer Repair - by Jake Blake - 05-28-2019, 02:33 PM
RE: 35-1285 Record Changer Repair - by sam - 05-28-2019, 07:12 PM
RE: 35-1285 Record Changer Repair - by R. Ramjet - 12-19-2020, 04:37 PM
Philco 49-1040
Philco 49-1040
There are currently 4198 online users. [Complete List]
» 1 Member(s) | 4197 Guest(s)
